Help Needed ASAP
Blake
sorry if this is in the wrong place and i know i already have a thred about this but i need the most feedback because may need to order my engine first thing tomoro.
basicly. cga14 engine into a cga10 k11, will it fit ?
i will just be geting the engine no TB or anything. from a 02 car for my 2000 will it work ok with all my 1.0 parts?
i am sorry to clog the forums just need help asap :)
blake
does your engine code say cg"a"10 ?
are they topfeed injector,s ? (with a stainless steel rail along the top)
is the chain inspection cover (on the end of the head) black steel or ally ?
first of all the engine numbers should be:
CGA3de and CGA1de
no such thing as a CGA14
but if you can get a CGA3de it would be worth it because they are hard to get hold of.
it should fit fine but you will need the ECU
