HELP: micra sounding like a subaru
mullet
hello all
this has recentley developed it used to be whenever it was wet and i had hit a few puddles but now it does it on start up it has that subaru burble which im pretty sure isnt normal i do have a blow in the exhaust but i dont think that would contribute much
any help appreciated
cheers mullet
Id say a missfire in a cylinder. Replace spark plugs. See if that solves it.
After that replace dizzy cap and rotor arm.
Should solve your problem
the back box is les than 3 months old so i cant imagine its that
ill try tyhe plugs and replace the dizzy cap and arm (the arm is less than 2 years old though ) anyway as the probs need done ha ha
check the injectors, unplug each one seperately while the engine is running and see if it makes a difference.
happened before with me when i put the 1.3 injectors back in and i didnt connect the plug fully.
check your ht leads as well as they might be broke, something my mates used to do was unplug one to make it sound like a subaru on idle so best checkin sparks ht leads and dizzy cap and arm :p
