Hi guys,
Nice forum - Has a good reputation around the web
I think my Micras dying.
I have a major problem with my K11 facelift 2002 1.0s Micra, 60k miles.
There is a rattly cog type high pitched grinding/rubbing type noise resonating from my gear lever, almost sounds like a blender motor.
Happens with clutch in/out and when the car is moving.
Whilst driving I could touch the gear lever and move it around and which makes the note of the noise change tremedously.
I can put it in a specific position and the noise will decrease significantly.
I tried it on coasting when doing 50Mph - I stick it in neutral car rolling but no change to high pitched noise???
Sometimes its impossible to find 3rd gear and at other times its smooth.
Car engages in gear ok most times and I know the gear linkage is a bit floppy.
Biting point is very low to the floor.
The fact that it happens in neutral gives me a little false hope that it might not be the box? (in denial lol)??
Input shaft Bearing?
Low oil? Need to check.
Clutch release bearing?
Any pointers most appreciated.
