I know it sounds lame with all sorts of serious tech problems being posted and discussed but our 95 K11 1.0 is running like a Singer sewing machine but has always suffered from very misted windows. .... sides, rears and sunroof.
Just to note, the car is super dry inside, no damp carpets or leaks .... in the past had the blocked sunroof drain and foot well flooding issue but long since sorted. Oh and the little green plastic insets under the front window cowling I sealed up at the same time to try fix same issue. Wander if a spin off from that?
Door seals are all clean, solid and seem work well. is a 2 door. Air is set to 'blow through', heater works well and blower solid.
But still it sits and mists like there's a kettle switched on in there!!!!
Any ideas to check or clever magic to sort this? Have tried putting RainX on in and out ... no real noticable difference. Even when it's been running 15 mins, the windows are still poor.
Appreciate any Micra specific or ANY guidance how to sort .... makes driving a decent little car somewhat miserable.
