Heating fan spead selector
Hi,
I didn't find a topic on heat fan speed selector, so here is my question:
has anybody had a problem with heat fan selector, in my case, only
one speed is working, 4th, and none of others.
I was told, that it is (maybe) somehow related to the water leakage
(http://www.micra.org.uk/showthread.php?t=9075&highlight=passenger+footwell)
that water is causing corruption of some parts that affects the heating switch operation.
Winter is coming :glare: so I'm eager to solve heating issues asap.
Hi,
The heater only working on speed 4 is a problem with your heater resistor card which is located underneath and to the left of your glove box.
You should be able to pick one of these up from your local scrappy, simple case of swap the cards and your heater will work fine!
Thank you, I'll try to find it.
Awesome, ive put up with that damn fan switch for too long! never got round to sortin it, cool cool ta.
