brim the rad with coolant and leave rad cap off.
turn heater dial on hot to bleed the heater core too.
start engine and run till it goes upto normal temp. the thermostat would then open to let coolant flow up into the radiator along with any trapped air that was in the system.
rev it afew times to further agitate air trapped inside to bubble up.
as the level in the rad goes down, fill up with coolant.
when no more bubbles appear, fit the rad cap back on, turn heater dial back to cold.
watch the temp gauge stays in the middle. when it gets too warm the fan should kick in.
once the fan turns off you can turn the engine off.
