Hoping someone can help, my front head light has stopped working the sidelight and indicator are fine. Have changed bulb and fuse but still nothing. Any ideas? Thanks........Anna
if you have a multimeter then check for power at the plug. also check the indicator stork. if the plastic case around it becomes loose then the connections are weaker...
also there is a special box in the driver's footwell that controls the lights check the plug. if not then the box could be buggered...
