Fordy said:check the fuse holder with the 2 headlight fuses in ( next to the battery ) take out the fuse and see if theres any green corrosion or even a melted or starting to melt fuse holder
rlees85 said:no.. theres a couple of fuse boxes in the engine bay too, so it would be the one nearest to the battery in the engine bay
stokefan said:OK I've checked the fuses under the bonnet and the one near the battery on the right doesn't mention lights on the cover of the fuse box, but the one on the far left does. I took the cover off and could see a big blue plastic (what must be a fuse) shaped like a cross, is this what i need to replace?
Thanks.
stokefan said:hi all,
found the problem....it's underneath the fusebox which the headlight fuse clips into that's corroded
Monkey_CSW said:
Monkey_CSW said:cant you take it out and sand the connectors down
Ed said:No one has pointed out the obvious, BUT if things keep blowing in the car CHECK THE ALTERNATOR. Its entirely possible that the voltage is going too high. You risk blowing all kinds of things in your car...
Ed
