S
Sesom
Hi,
I have searched the posts but found no answer to my problem so I've decided to create a new thread.
I am almost ashamed :down: to admit my Micra (K12) is giving me a tought time replacing the main headlight bulb. The instructions in the user handbook are straightforward: Remove the contacts, the rubber protection and release the wire clip. Remove the bulb, replace it with a new one and repeat everything in reverse order. I am stuck at step one. I cannot remove the black plastic contact. Is it screwed on or something? If anybody has done it I will be very happy if you could post instructions.
Thanks in advance,
Primoz
Thanks in advance,
Primoz
