GTIR Brakes
the pulsar are 4 stud i had them on my micra or even almera gti breaks will fit all you need it 2 1mm washers inbetween the carrier and the hub
What are the 1mm for? I wouldn't have thought it's necessary with a sliding piston design caliper?
Also do you use the sunny discs?
hmm.. 280mm here I come.
Because otherwise the carrier hits the disc , nothing to do with the caliper
you need the washer to center the carrier and pads to the disk if not the pads would wear down faster than the other and give un-even breaking
I see, that makes sense! Any 1mm washer will do?
Do you use GTI-R brake discs? I suppose these will fit under 14-15" wheels?
