makes a noise when spinning, but not a wheel bearing noiseJack it up, try spin the wheel and try rock it side to side to check for play then come back with your findings...
sounds like it. taking it to my gf dads garage tomorrow which is 35 mins from here tht motorway journey will be interestingDisc's could be pitted/warped. Mine used to do it when braking hard.
nah cz its not a constant noise and it also when im not braking it does itBrake pads down to the metal? Brakes tend to be hot btw
sounds the same but struggled above 60 on a 70My old car my Matiz done this once, pulled out onto a 60mph road and couldnt get it above 30, felt like i had a flat tyre
Pulled over eventually and the disc was glowing red
Was fine once i started moving again, but the brakes felt like cream cheese for the rest of the night, was fine the next day :L
Must have got something like a stone ect stuck
Sounds like the same problem i had on the drivers side, the piston in the caliper just ceased up - It cooked the wheel and the tier wouldn't hold air for very long after that.
Went to the breakers got another caliper for £15, haven't had a problem since![]()
