pork Club Member Aug 10, 2012 #1 Bit crudded up tho Good clean up and should be ok.....right? Start making plenum template later
karlj Aug 10, 2012 #2 Definitely need a clean , If I was you I'd use a small turbo on low boost to start with, really wish I'd seen this idea through to the end
OP OP pork Club Member Aug 10, 2012 #3 He did state they have been sat in she'd for a year. So you reckon a t15 like frank suggested will do the trick?
karlj Aug 10, 2012 #4 It should do but I'm by no means an expert, I was going to use a t2/25 with the boost right down to 5psi to start with
Skinner_87 Aug 10, 2012 #5 Good rinse out with petrol should help eh Pork, i found this usefull as well.......... http://www.totalvauxhall.co.uk/files/2010/10/64BIKECARBS1.pdf
Low Rider Poindexter Founding Member Moderator Club Member Aug 10, 2012 #6 Skinner_87 said: Good rinse out with petrol should help eh Pork, i found this usefull as well.......... http://www.totalvauxhall.co.uk/files/2010/10/64BIKECARBS1.pdf Click to expand... Good write up that. I should consider myself lucky that my Jenvey setup was within £150 of their quoted kit price
Skinner_87 Aug 10, 2012 #7 Low Rider said: Good write up that. I should consider myself lucky that my Jenvey setup was within £150 of their quoted kit price Click to expand... A bargin!
