porkpie700
Buy & Sell Member
Just covered 220miles with my new MA12 and something has gone horribly wrong somewhere deep down in the block...
Engine starts and idles as usual, but it's when the engine is reved to a particular rev-range (i would estimate it at 2000rpm upwards) it gives off a very loud, dry gnarly grinding rattle from the bottom of the block in the cylinder no.1 area.
Any gear, even with the clutch dipped. It hasn't lost power or economy but it does have a tiny dead-spot on the throttle. My friend followed me home when it started to do it and noticed a small puff of blue from the pipe on gear changes.
Suspecting that it's the big-end bearings or worse i have already cleaned and painted my origional MA10 ready to go back in if needed (austin-morris green of all colours).
Someone suggested that mayby it's not as serious as it sounds and might be the oil pump, water pump or timing belt tentioner. My oil pressure is good, cooling system is doing a fine job, the tentioner i wouldn't expect to produce a rattle that can be felt right through the car like that...
It's worth mentioning that i have checked the rocker bar, cam and valves for any play but they're all tight... very tight. Yet a harsh click/knock is sometimes heard from the cam area when revved suddenly but that has been there long before this new noise.
Close-est sound i can give you is when a washing machine is emptying and then the pump runs dry and you get that rough gnarly growl from it.
Has anyone out there experienced this problem and if so what was it, any help as always is greatly appreciated.
