CMF_germank11
» CMF MemberHello everybody,
i received a email from matthew, thats what he said:
"Picture 4.
This one is going to be difficult.
Plug number 6 connects to a block connector under the dash and in the centre close to where the ECU is located. Have you still got the original ECU fitted?
---the problem is, i know where to fit, in the middle between the black and white/yello wone, but i don't know what it is for---
Plug number 4 is for the wiper motor, one small problem you might find is the block connector will not reach your wiper motor because this loom is for a RHD car and you have a LHD car so the wiper motors are on different sides.
Plug number 5 goes onto the fast idle device on the front of the air flow meter.
Plugs 1,2 and 3 look like they are for the piggy back ECU, one is possibly and live and earth. You need to trace these back the to piggy back unit. 2 might be for the water temperature sensor, this is who the piggy back unit gets the standard ECU to increase the fuelling by sending false reading back from this sensor. Have a look at the instructions I sent for the Piggy back unit."
---i have looked to the instructions, but there are no informations about the installation of the piggy back. Could someone tell me where to locate the water temperature sensor? Later i will get back into the garage and have a look on the harness/ecu and #1 and #3, but i'm a little bit afraid to connect it wrog and damage the whole ecu, don't want to cause a short circuit...---
"Picture 4.
