:k11motors Hi had several micras, mainly k11 s
problem at moment is gears hard to select when cold, mainly 1st to 2nd and sometimes fifth, (99 1 litre inspiration ) changed gear oil some while ago and used halfrauds ep80...........................................................................
i heard that you should only use the recommended NISSAN gear oil in these boxes,
Any comments, advice would be appreciated
t hanks:grinning:
t hanks:grinning:
