Hi Guys,
Just a tip for those of you with a newer style gearbox with a speed sensor instead of a speedo cable ('98 on?). If the nut in the refill hole at the front of the box is impossible to shift, you can refill via the speed sensor hole at the back of the gearbox. You need to remove the airbox to get access, then remove a 10mm bolt holding the sensor, twist anticlockwise and pull out. It's actually easier than using the proper hole.
Sorry if this repeats older threads, most of the ones I read were relating to the older box so i thought I'd stick this in for general info.
Spike
Spike
