Got a 2001 1.0 k11 micra s
Has like a friction noise coming from gear box but I'm sure it remains even with clutch pushed down (will check again)
It's not very loud but is noticeable, can only describe it like the noise brakes make when pads start to wear. Low pitch rubbing kinda noise.
It kinda changes pitch/sound when i put slight sideways pressures on gearstick while in gear.
Hoping its low/old oil, Rather than thrust bearing etc.
How do I check gearbox oil level on this model, have seen a few posts for the preface lift.
Also what gearbox oil should i use for this model?
Thanks for now
Thanks for now
