Hoping somebody can help.
Had my 2000 1.0s (yes that the sports model)from new. After about three years the gear lever seemed to be getting stiffer and stiffer to move. First to Second and Third to Fourth seem to be okay but, Second to Third and Fourth to Fifth are quite a struggle unless you take your time, then its time to change down again. You have to force the lever up and over to get to fifth and coming back to fourth can be a challenge. The lever is stiff across the box in neutral and does not spring back from fifth and gets stiffer as the car gets warmer. The Car has been serviced in line with Nissan guidelines.
Thanks in advance
Lee
Thanks in advance
Lee
