Gearbox help please
I'm after a prefacelift box with a speedo cable drive, to fit a 1.3 engine, I'm just wondering if the 1L box fits with no mods and am I right in thinking the neutral switch needs something doing to it?
The only 1.0 gear box I heard fits and runs direct is the very early face lift on from 99/00 ones that would have the mechanical speedo drive too.just like mine :)
a whole batch of things to swap over if you went with preface 1.0 box.
drive shafts .flywheel. gear selector rods are different.
heh, clear as mud innit zed :) the idle control valve can be fitted remotely if needed, or else deleted completely (like mine was) and the preface 1.0 g/box has a different wiring connector for the neutral and reverse switch
