ga16de ecu
jabran200
Will the ga16 ecu plug and play ont he micra or is wiring needed to be done? I am interested In running a 1.6 ecu,injectors and tb.
Jabran
yes it can be done (for a non nats setup) although even if you do all that its not really that accurate as the engines have different VE maps, so you may still end up with some running issues.
Thanks for that Ed.
Yeh I know the VE will be different but I am thinkign of using it for a different purpose altogether.
