Ga16 TB & injectors
Alessandro
Club Member (Trial)
I'm going to fit these parts on my Super S.
I've just make the blanking plate for the TB and it's all ready to fit!
I need to know something else before fit these on my cars?
P.S.My car have NATS .
go for it, should have no problems when it all fits, but really you will not see any power gains and you should get the car mapped. problem is the 1.6 injectors let in more fuel than the 1.3 ones, but the ecu wont know that so you may just run the engine rich.
alessandro
a pic of your adapter would be interesting :cool:, apparently, mine was too rich at low revs and still too lean at high revs with the 1.6 t/b and injectors at WOT (but in closed loop it was ok).
so i went back to stock injectors + a 5th injector in the t/b
I only made the adapter with a plate of wood for testing!
If the TB works I'll made one in aluminium.
I'll try the GA16 injectors if it will be too rich a reput the stock ones.
What mods do you have on your Micra Frank?
I saw your blog.
You're really good to make mods yourself!
it's really interesting the 5th injector in the tb.
For fill the holes in the tb you use liquid metal instead of a plate?
alessandro
the 5th injector is very crude tho :wasntme:, it will run the car on it,s own at 70 mph, so it probably dumps too much fuel and i only use it at high revs.
and yes, the holes were filled with chemical metal (but one was drilled out again, for the injector)
I'll post my impression with GA16 tb + GA16 injectors and GA16 tb + stock injectors.
I'm thinking also if I'll run the tb with the original injectors to put a fuel pressure regulator.
