its a 2000 1.0 shell, done around 90'000 ( will confirm becuase i forgot to check), mot ran out in may, been parked up since january and before that had done 6000 miles in 3 years, was damaged when the garage i worked for brought it, and was repaired to a decent standard, had bumper and wing fitted, shell is in good condition,slight rust on crossmember where they all rust, interior good, pollen filter removed so heater works better, seats missing as my dad used them in his sales car,
the engine: a 1.6 ga16 out of a primera, brought from the local breakers who we know well, fitted on the 1.0 box, currently running on 1.0 clutch and flywheel which was modified to fit, gearbox slightly off engine give clutch freeplay, the drivers mount was modified and welded to fit by myself and uses the primera mount, and front mount made by the guy i worked with, wired in on the origional loom which i modified to fit, water pump has been removed and had a blanking plate TIG welded onto the end to get it to fit into the car without chassis modification.the power steering is blanked off but gives a better feel, hoses have been plumbed in and the top hose has been made to take a temp sender from the electric water pump, running the 1.0 rad but have a almera rad to go with the car, the battery has been relocated to the boot but needs securing, it runs and does drive, i havent ran it for a long period as it doesnt have cooling. its a great project for someone to finish and i really would have if i hadnt brought another car out of desperation,
