Fusion Motorsport Announces Omex Technology Systems
Ed
Fusion Motorsport
MSC Founder
Official MSC Trader
Fusion Motorsport is proud to announce that we are now suppliers of Omex Technology Systems (Omex Electronics).
About Omex. Omex is a manufacture of very high quality engine electronics supplying to the fast road and motorsport markets.
Their product range includes their very respected range of rev limiters, shift light and launch control systems. All of which feature Omex's acclaimed method of calibration eliminating any instrument error by working independently of the vehicle's tachometer.
They are suited to virtually all injection or carburetored engines. Amazingly prices start at just under £85 for the Omex 'Rev Limiter Clubman' – an ideal addition to K10 range of Micras that have no factory rev limiter as standard, with other options such as launch control and shift lights at just £115, there is something for K11 owners as well.
Also we would like to announce that official members receive a further 5% discount off these prices shown below.
Featured Products:
Only £85
The Omex Rev Limiter Clubman features an extremely smooth rev-limiting action and a selectable hard or soft cut.
The standard unit is suitable for most 2, 4, 6, or 8 cylinder single coil engines that use points, electronic, or ECU ignition.
The twin coil version is designed for use on 4 cylinder twin coil (DIS) engines.
OMRLC Rev Limiter Clubman
OMRLCT Rev Limiter Clubman Twin Coil
Only £110
The Omex Rev Limiter Clubman with Launch Control features an extremely smooth rev-limiting action and a selectable hard or soft cut.
It also has an auxilliary rev limit which is operated with the supplied waterproof switch that can be mounted on the stearing wheel or the gear knob.
Set separately to the main rev limit, the auxilliary limit is used at the startline to prevent wheel spin or the engine 'bogging down' enabling very consistant results.
The unit is suitable for most 2, 4, 6, or 8 cylinder single coil engines that use points, electronic, or ECU ignition. The twin coil version is designed for use on 4 cylinder twin coil (DIS) engines.
OMRLCLC Rev Limiter Clubman with Launch Control
OMRLCLCT Rev Limiter Clubman with Launch Control Twin Coil
Only £115.
Similar to systems found in Formula 1 and the BTCC the Shift Light Sequential has 4 coloured LEDs in an external module (40x16x13mm) which light sequentially in up to 600 RPM programmable stages as you approach the user definable shift point.
OMSLS Shift Light Seqential
Some very nice stuff there, i looked into Launch controll stuff a while ago, so may possibly be interested it it :)
They are very good. We used them on the Fusion Evo, and pulsar. I also trialed it on the ST at santapod :)
