Fuses problem!
Corbs
Had a lot of trouble with this, my K11 pre-facelift has started to eat fuses, it's always the tail lights and dashboard lights that blow at the same time, randomly! 3rd time its happened now and I'm getting fed up with it! Any ideas as to where the problem may lie?
check all the wiring connectors and relevent earth points are clean and secure, also check that the back of the fuse box is ok as they do have a tendency to melt causing all sorts of problems.
When i was having trouble with the radio wires it would blow the radio fuse and the Rear Tail Lights fuse, so it may be something to do with the radio
