Fuse Box under the bonnet
Hi
Please can someoe explain how the top comes off the fuse box under the bonnet and in front of the battery. It is my daughter's car and I can't get to the fuses.\
two clips either side, normally a strong flat blade screw driver will help you prise the left one open and then the right one will open by itself.
Be careful though as you can break the clips if you put to much force.
As above. That fuse box is very prone to getting damp. The headlight and fuel pump fuses/holders corrode. Give it a clean and a spray with some WD40 while you are in there.
