Fuel Pump
CMF_fred
fuel pumps won't do much until other stuff is done (injectors, mapping, ignition, headers, exhaust, adj fuel regulator....(turbo?) so if your not planning anything else, it'd be a bit of a waste.
CMF_Snoopy
Pull the pump assembly out of the tank and have a look its not that hard. The skyline pump fits so it should be fairly easy to make the walbro one fit. What 255lph did you get the gss-341 or the gss-342? I just installed the gss-341 into my swift gti today not too hard. You will find the walbro pump is probably smaller in diameter then the micra one, so you will have to take that into consideration.
