CMF_giannishazel
well i do have a 255 spare bosch fuel pump and i am planning to put it on my micra.i will use ga15 injectors,k11 fuel rail and regulator on a tunned cg13 engine.my micra pump already has 200.000klms and since i already had this sitting on my garage i am planning to put it in.has anybody install a 255(walbro,bosch) on his micra?will it be ok with the fuel relay(or ecu) or the safety amps?
CMF_giannishazel
thanks wudi.have you done other mods?like puting a bigger amps fuse? cause i think that since it is a bigger pump maybe it will need more amps to work properly.
CMF_deNs
wudi WROTE:
"Hey, I fitted a Walbro 255 pump to our vert a few weeks ago. Nil dramas as it came with a full install kit. Wiring was straight forward.
Did the same with the Walbro GSS341 I put into my LX. Plug and play (effectively, just soldering the K11 plug to the +/- tails). Use standard fuel pump fuse (10A from memory) and that's it.
I had a Bosch 040 but decided it was overkill for my setup. You shouldn't have any issues.
---dens
