CMF_Tyrie
» CMF Member1996 Series 2 K11 LX Nissan Micra
ACT rego 23 Nov 2012, engineered
Body Coloured Bumpers,mirrors, doorhandles
~220,000km on body, recent low km jap import engine installed
Modifications
-Microtech LT8 ECU
-Custom Turbo Manifold
-2.5" Exhaust From Turbo Back
-Reconditioned Garrett Turbocharger
-Modified S13 Fuel Rail
-Bigger Injectors
-CoolingMist Water/Methanol Injection System (not currently working, was set up to squirt water into inlet when positive air pressure but wasn't tuned for it)
-S14 Sidemount Intercooler (Top mounted)
-3:1 Malpassi Fuel Pressure Regulator
-Walbro Intank Fuel Pump
-Turbosmart Dual Stage Boost Controller
-Driveline
-Datrats Custom Heavy Duty 190mm Clutch
-JUN Lightweight Flywheel
-X-Racing Short Shift Kit
-Suspension
-HKS/tein/KYB coilovers
-#bnf30 - Heavy Duty Fixed Replacement Front Swaybar (22mm)
-#kca373 - Castor/Anti Lift Kit
-#kca412 - Camber Bolt Kit
-#kpr025 - Adjustable Panhard Rod
-#ksb708 - Alloy Lower Control Arm Brace
-#bnr29xz - Heavy Duty Adjustable Replacement Rear Swaybar
-#kta114 - Adjustable Lower trailing Arms
-Jap brace across the top seatbelt mounting points in the rear.
-Braking
-Front N15 pulsar vented disk brakes
-Rear new shoes and cylinders
-Wheels/Tyres
-15x6.5" 6spoke alloys with Federal 195/45R15 tyres (engineered with 15x7", can sell these with the car but would prefer not to)
-Miscellaneous
-SAAS bucket racing seats (not lised on engineers cert, buyer has option of the SAAS seats or standard LX seats)
-Mostly stripped interior, can include carpet, back seat, trims etc
-Mulholland 6point bolt in cage
-Sports steering wheel
-Aufra Mini-Tacho Guage
-Aufra Boost Guage
-Aufra Exhaust Temperature Guage
-Aufra Oil Temperature Guage (all 4 gauges not currently fitted, all were wired up but none of them worked...)
-Clear Side Repeaters
-Power steering conversion from a SLX micra
-Kenwood KDC8023 Cd Player (I recently had the dash out replacing the heater core and now it doesnt switch on, probably someting very minor)
-Viper 791XV - Remote Start Alarm System With 2 Way Pager
Price is $4000 with the cage or $3500 without.
Clearcoat a bit rooted on upper surfaces. I had it dyno'd when I bought it and it made 93.3kw atw at 7psi.
The turbo manifold currently has a small crack in it, is easily accessible and I will get it welded up if I can spare the time before it is sold.
http://a3.sphotos.ak.fbcdn.net/hphotos-ak-prn1/11779_460730467275823_214501475232058_2005075_1472 185774_n.jpg
http://a7.sphotos.ak.fbcdn.net/hphotos-ak-prn1/541326_10150676967521387_537426386_9388930_6790041 58_n.jpg
http://a7.sphotos.ak.fbcdn.net/hphotos-ak-ash3/554984_10150665064156387_537426386_9353002_1559770 976_n.jpg
It does skids
[video=youtube_share;p8uT0YcvlXg]
Modifications
-Microtech LT8 ECU
-Bigger Injectors
-Driveline
-Suspension
-Braking
-Wheels/Tyres
-Miscellaneous
-Aufra Boost Guage
It does skids
