FS: Series 2 K11 Micra turbo (ACT)
CMF_Tyrie
1996 Series 2 K11 LX Nissan Micra
ACT rego 23 Nov 2012, engineered
Body Coloured Bumpers,mirrors, doorhandles
~220,000km on body, recent low km jap import engine installed
Modifications
-Microtech LT8 ECU
-Custom Turbo Manifold
-2.5" Exhaust From Turbo Back
-Reconditioned Garrett Turbocharger
-Modified S13 Fuel Rail
-Bigger Injectors
-CoolingMist Water/Methanol Injection System (not currently working, was set up to squirt water into inlet when positive air pressure but wasn't tuned for it)
-S14 Sidemount Intercooler (Top mounted)
-3:1 Malpassi Fuel Pressure Regulator
-Walbro Intank Fuel Pump
-Turbosmart Dual Stage Boost Controller
-Driveline
-Datrats Custom Heavy Duty 190mm Clutch
-JUN Lightweight Flywheel
-X-Racing Short Shift Kit
-Suspension
-HKS/tein/KYB coilovers
-#bnf30 - Heavy Duty Fixed Replacement Front Swaybar (22mm)
-#kca373 - Castor/Anti Lift Kit
-#kca412 - Camber Bolt Kit
-#kpr025 - Adjustable Panhard Rod
-#ksb708 - Alloy Lower Control Arm Brace
-#bnr29xz - Heavy Duty Adjustable Replacement Rear Swaybar
-#kta114 - Adjustable Lower trailing Arms
-Jap brace across the top seatbelt mounting points in the rear.
-Braking
-Front N15 pulsar vented disk brakes
-Rear new shoes and cylinders
-Wheels/Tyres
-15x6.5" 6spoke alloys with Federal 195/45R15 tyres (engineered with 15x7", can sell these with the car but would prefer not to)
-Miscellaneous
-SAAS bucket racing seats (not lised on engineers cert, buyer has option of the SAAS seats or standard LX seats)
-Mostly stripped interior, can include carpet, back seat, trims etc
-Mulholland 6point bolt in cage
-Sports steering wheel
-Aufra Mini-Tacho Guage
-Aufra Boost Guage
-Aufra Exhaust Temperature Guage
-Aufra Oil Temperature Guage (all 4 gauges not currently fitted, all were wired up but none of them worked...)
-Clear Side Repeaters
-Power steering conversion from a SLX micra
-Kenwood KDC8023 Cd Player (I recently had the dash out replacing the heater core and now it doesnt switch on, probably someting very minor)
-Viper 791XV - Remote Start Alarm System With 2 Way Pager
Price is $4000 with the cage or $3500 without.
Clearcoat a bit rooted on upper surfaces. I had it dyno'd when I bought it and it made 93.3kw atw at 7psi.
The turbo manifold currently has a small crack in it, is easily accessible and I will get it welded up if I can spare the time before it is sold.
http://a3.sphotos.ak.fbcdn.net/hphotos-ak-prn1/11779_460730467275823_214501475232058_2005075_1472 185774_n.jpg
http://a7.sphotos.ak.fbcdn.net/hphotos-ak-prn1/541326_10150676967521387_537426386_9388930_6790041 58_n.jpg
http://a7.sphotos.ak.fbcdn.net/hphotos-ak-ash3/554984_10150665064156387_537426386_9353002_1559770 976_n.jpg
It does skids :)
[video=youtube_share;p8uT0YcvlXg]
CMF_Tyrie
parts list below. I wouldnt start stripping it until the turbo/microtech are spoken for though.
microtech and loom 500
Turbo manifold+turbo+intercooler/piping/2.5" exhaust 1000
modified 13 fuel rail and 2 sets injectors 200
water/methanol injection / intercooler spray 100
malpassi rising rate fuel reg 75
Walbro in tank pump 50
turbosmart dual stage boost controller 50
JUN flywheel and datrats 190mm clutch 300
X-racing short shift kit 50
HKS/tein/KYB coilovers 500
whiteline front swaybar 100
whiteline rear swaybar 100
Castor kit and camber bolts 75
Alloy LCA brace 100
Adjustable trailing arms 150
rear seatbelt brace 100
n15 front brakes 100
15x7 4spoke with 195/45R15 federals 500
SAAS bucket seats 200
Mulholland 6point bolt in cage 500
Sports steering wheel and boss 80
Gauges 100
clear side indicators 50
Power steering conversion 350
Kenwood CD player 50
Viper remote start alarm 50
31A gearbox and jdm vlsd driveshafts 500
left door 25
right door 25
Hatch 25
hatch handle 25
bonnet 50
Front bumper 50
rear bumper 50
LHF guard 25
RHF guard 25
rear axle 50
dash 25
CMF_Tyrie
rad100 WROTE:
"im interested in coilovers.
front and rear?
Rears aren't height adjustable, is just a tein spring and kyb shock setup. Front is HKS height adjustable struts with tein springs.
Cage may be spoken for.
Reason for parting it out is a small gearbox issue at yesterday's motorkhana. I'ts a four speed box with no reverse now!
