Front Hub Bearing
solarice
Anyone changed one of these before ?
Dismantled mine and theres two bearing rings (they run on the hub itself), circlip and two oil seals...now i went to get a replacement set, and instead of the two bearing rings theres just one big bearing ring :S
Now the box code matched to the catalogue and to the correct year so its for the correct car, so unless the contents are somehow different (gotten mixed up) then im unsure...the guy i was talking to had never changed one himself so wasnt sure. This was a quinton hazell part btw.
Cos its either that the contents are wrong or my hub is different (unlikly)
So can anyone confirm which one it should be. :)
