CMF_Alienfish360
» CMF MemberOk..... I'll be doing a turbo conversion on a CG13DE. I will be fabricating the manifold and exhaust system myself.
I will also be mapping it myself.
Now, I can understand the fuelling etc, however I'm a little lost with the mapping of ignition timing.
I've read that the HKS kit for the CG13DE from the Cube will run 5 psi on a standard ECU etc etc etc.
Now, will I be able to run 6-8psi with an intercooler on standard compression and standard ignition timing?
If not, will I get away with turning my dizzy cap, to retard a couple of degrees and a couple of grades colder on the plugs? I know it's not the proper way, but until I plan to run bigger boost, I don't really want to touch the mapping of the ignition timing.
