fog light relay
Enuo
Glorified Electrician
Front fogs not working, where the hell is the front foglight relay? Haynes manual isn't clear, and from wiring diagram is only thing left to try other than the loom itself. Earth is fine, fuse is fine, switch is fine, bulbs been replaced... and my multimeter is off being calibrated :(
under the bonnet, on the o/s/f inner wing theres a relay box, its in there the one furthermost away(providing yours is a RHD micra) it should be black
turned out for some reason there were multiple breaks in the loom, so wired up a new relayed switch to them with returns straight to the battery.
Write your reply...
