Flywheel
CMF_33driver
you can buy em in australia, but they are not cheap
you can lighten your standard one, just get it done by someone that knows that they are doing. Don't lighten it too much though or it will crack and go boom :)
CMF_frank2
machining the ring from the back has a marked effect, because its at the greatest diameter eh (GA16 one in the pic, which allows a bigger clutch)
CMF_daily_ricer
If you're willing to pay $600 for a flywheel, why wouldn't you import something? I know prices would have changed a bit over the years, but the ultra-light weight Jun flywheel was pretty cheap when I got it.
https://micra.org.uk/cmf/message/32874
http://perfectrun.jp/src/detail.php...9&result_mode=qui&cbid=101&carid=101042_10110
Not sure if that last link will work, but the perfectrun site is quoting AU$475 for the 3.6kg ultra-light weight one plus postage. I paid $390 plus $80 postage for it through them back in 2008.
https://micra.org.uk/cmf/message/38085
CMF_Pierce
bahahaha the best news ever... My old green micra (my daily), the one that just blew its clutch, well I decided to throw an exedy oem replacement on and when I took it off... Behold there was a fully machined flywheel lookin just like frank2's...
Now swapped with the standard one on the black 3door slx I'm rebuilding :)
CMF_frank2
Tinky WROTE:
"That's a great find pierce :) Thanks Frank...looks like Swiss cheese..must spin though. Do you have the rev limiter disabled ?
it was disabled when fitted to 1.0 engines tinky (and revved to nearly 9k) but not on a 1.3
here,s me balancing it in feb 08 :)
