Flywheel and clutch question
Snikty
Site Supporter
Is the ST flywheel the same as all other k10s or possibly any k11s?
Is the clutch the same as the fig and pao clutch? I see exedy make an organic clutch for them and thought it would probably be a suitable option.
The nismo clutches are often listed as suitable for k10s and cg10 k11s....can anyone confirm for me the part numbers of the face plate and cover for the one that suits the ST? I vaguely recall it being said once before that the nismo cover is a good upgrade but the paddle style face plate is prone to slipping, can anyone confirm??
Thanks heaps.
It should be physically the same size as a K10 one but its drilled differently due to larger clutch.
All Fig are autos, PAO is the same as a K10. 1.0/1.2, not the ST.
K11 friction plate is fine for about 180lb/ft on the ST, if used with a Nismo cover, The K11 cover would possibly fit the ST but the release bearing is different, there may be a combination that would work, I've neved needed to find one.
Paddle cerametalic is not necessary and is horrible to drive and very hard on the box.
