hi would anyone be able to tell me the steps needed to flush my boot??
step one:
take it to a body shop
step two:
pay the body shop
step three:
fit the flush gate
seriously it is not easy. to get it perfect you need to be skilled with metal bending and welding. filler wont work.
really shouldn't use any filler on a smoothed boot because the first time you close the boot you will shatter the filler...
how much would it cost for body shop to do it including the spraying??
to get a perfect finish you should always use filler, however i agree that you shouldnt go chucking loads on your numer plate recess. however once the metal is welded and grided a good skim with filler will make sure all surfaces are flat, shaped properly and smooth
Lead filler is much better, old school pro's use it alot.
Worth using it instead if you can.
I'm making notes now for a smooth boot project now
Using filler is an art, anyone can slap it on and do some sanding but ti get it to blend with the body and the curves takes an accurate eye, worth trying on spare body parts.
Any pics of your progress Gam?
Hold it! If you intend using a lot of filler remember lead filler is made of...lead! Do you really want to whack a great lump of lead onto your tailgate?
Decent body filler is easier to use and lighter than lead filler. Thats why most bodyshops use normal filler and not lead filler.
it might get stuck in the U-Bend mate... dont flush...
