CMF_Tone
» CMF MemberCurrent fault is a flat spot for first 1/4 throttle worst when cold, would assume fuel conumption is up however is too rough for wife to drive.
A battery change fixed misfire / flat spot problem for one round the block trip (see post from weekend). It must have warmed up!
When driving 95 Micra 1.3 unless driving like maniac ie constant in Ds N-CVT the engine shudders misses and generally does nothing flat spot for 1/4 throttle.
Have done throttle body mod some 2 years ago which fixed won't idle fault (thanks again) have checked fault code on eccu led and have 55 (nil fault).
Any suggestions on what to spend the hard earned $ on first?
Thanks in advance you are certainly helping the Micra community.
Sorry to kep bothering you guys but your stuff has really helped in the past.
