R
rod
Are we all agreed the WHOLE GEARBOX must come off - not just the drive-shaft etc on the Clutch side ? What are these things you have to prevent falling into differential - that sounds scary !
Phil_the_Chill said:Speaking of the smelly gear oil. Is there a way to drain the gearbox fully.. I mean with the plug out you still get quite a gush when you pull the driveshafts out. I am planning another dismantling soon and would like to avoid the savings on the garage bill being spent on new clothes. If one were to take the plug out the day before and leave it dribbling overnight perhaps??
rod said:Are we all agreed the WHOLE GEARBOX must come off - not just the drive-shaft etc on the Clutch side ? What are these things you have to prevent falling into differential - that sounds scary !
bobsp16 said:WERE DO YOU LIVE???
I can do one in about 2 hours i changed mine on saturday between races
Dont use a broom handle you narner use a 1/4 drive 7/16 long reach socket to line up the plate up
il do it for about £160
antony_aiken said:seriously..how bad does it smell?
