fitting replacement distributor / setting timing
hi all, have now sourced a replacement distributor for a 1999 micra 1.0 litre,
i will mark the position of the old distributor, but apart from plugging it all in is there any other setting up to do,
i read somewhere that you have to unplug the throttle position sensor and then plug it back in.
any advice would be much appreciated
the t/p/s removal is for strobe setting the timing jeepster, and there was a pdf manual link posted last month :)
