Fitting a Tow Bar
Demarest
Does anyone know, or has anyone managed to fit a tow bar/ball to a k11?
Also, is there alot of electrical work involved?
:k11green:
(apologies if this is under the wrong section)
Towbar
I've done it and it is not that difficult. If you buy a new towbar, you will get an instruction manual.
I bought an used towbar from a scrapyard! I got all bits and pieces except two brackets whisch is fitted in a kind of channel, so I had to make them my selves.
The wiring is only to connect the different wires from the towbar to the wires to the rear lights. I used Haynes Manual wiring diagram for that.
Check out the following websites (do a search). I found instructionmanuals there which gives an indication of what is needed. Bear in mind that there is different solutions how different brands og towbar is fitted.
BOSAL
BRINK
did mine for myself and it only took me about an hour to fit the bar but the wiring is a b*tch because the haynes manual i have was wrong!! so it took me ages with the multimeter....
