T
technium
Hi
Just found this forum so thought I would ask a few questions I have.
1) Is it just mine or other K11's that have problems with putting in fuel, ever garage I goto I cant seem to get fuel into the car without doing it really slowly otherwise the pump nossle stops, Ive tried turning the pump nossle at different angles but it still does exactly the same. Ive never had this problem with any other car Ive had just this one.
2) The Aerial cable in the car I was told should be like a tv aerial with the main metal bit in the middle and then the outer wire sheath, anyway ive tried to use a connector (old stereo just ripped out!!) so that I can get radio in my car but the grey aerial cable is thin and has the outer wire sheath but the centre wire is only tiny thin pieces of silver wire not thick like tv aerial so everytime I screw the connector screw onto the centre wire to hold it in place it just breaks, is this right?? is it meant to be thin strands?
3) Also is there anywhere you can download the service manual on pdf or anything like that at all?
thanks in advance
T
thanks in advance
T
