Few Performance Questions
Anto Modded
Based on a 1.3 k11
1 - with a full decat system and a FSE Power Boost Valve and a 1.6 throttle body and injectors, what kind of power figure would be expected
2- With the above done can the car be remapped with standard ecu.
3- Without cams what kind of mods can be done to get the best bhp from a 1.3
Just im trying to make a good track car to give some of the bigger yokes a run for there money from a modded n/a micra
1.1.6 tb and injectors will do nothing. neither will fse around 85bhp @ fly with janspeed.
2. need piggy back, or see ed regarding mapping stock ecu
3. turbo, supercharger, nitrous, head. A lot of things
the CG TB and Injectors are good for around 150BHP, so why change them??
Power boost valve won't really do anything.
Janspeeds about the only gd thing you got there.
A good thing to do would be a custom inlet manifold, a better flowing one, get cams fitted, get Ed to re-map your stock ECU
Im from ireland, so ed is a bit far. I dont know much about the tb and injectiors so saves me money if i dont have to change them. So i guss its exhaust and cams and a remap to go for. Thanks for the advice
CG13DE injectors are not capable of 150bhp. You start to hit fuelling problems very early on with the 1.3, most do not know this as very few people ever re-map their cars.
