Ill start off with the pictures
7j
6J
8 extended studs for rears
spigots, spacer and 60 degree tapper washers
Shaun has got very similar setup on his car. here is couple of pics
now about the wheels
1x 7x13 et5 4x4" (4x101.6) This wheel is used on the narrow side of the car after the panhard rod has shifted on lowereing. (or with a 10mm spacer - supplied if wanted)
1x 7x13 et -7 4x4" (4x101.6) This wheel is used on the wide side of the car after the panhard rod has shifted on lowering.
2x13 Et 13 Double drilled 4x120 & 4x100.
Comes with 4 good part worn tyres, two fitted, two not
open to offers
7j
6J
open to offers
