Squizza
Hi peeps,
Just want to warn you incase you weren't already aware!!!
I recently put some extended studs on my K11 Micra 1999, and had a very scary noise coming from the front!
So if you have extended studs and you get a noise that sounds very pressurised, pops, bangs and, scrapes here is the reasoning oh and I eventually got brake pedal trembles!!!
The garage had a look over, and due to length and amount of wheel changes they had unseated the brake discs and therefore that been the problem! So just reseat the disks
