Exedy heavy duty 190mm clutch
cisco
Here's some pics of the 190mm pulsar clutch that I was going to fit. Just wanted to show you the beefed up diaphram section with the obviously wider fingers.
Turns out I had to get this same diaphram fitted into my existing clutch plate cover, as this cover in the photos doesn't bolt up directly to the micra's flywheel.
However Errol is working with exedy to get an off-the-shelf 190mm clutch option for the micra made up the same as this.
This is the friction plate.
cisco
Pressure plate again.
Check out those chunky fingers!
cisco
As a comparison, check out the skinny/softer fingers on the old pressure plate which ended up cooked.
