evade's old engine..stripped
CMF_evade
So I FINALLY took my old engine apart today.
Looks like it died from what I originally suspected..blown headgasket..
and it blew in a pretty hardcore way too..not just one cylinder..two of em..
Also noticed some of the crankshaft bearings were a bit worn, other than that the engine seemed OK, pistons were fine, rings were fine..
<img src="http://aaronactive.net/gallery/d/16195-2/IMG_6225.JPG">
<img src="http://aaronactive.net/gallery/d/16177-2/IMG_6219.JPG">
More photos here
http://aaronactive.net/gallery/v/cars/aarons/micra/oldengine/
cisco
Holy ****, that thing's had a hard life :)
That is hardcore.
Nice pics.
CMF_evade
Yeah its been more than a year since that engine has moved from my backyard hehe..
but yes, it went out in a good way..so I suppose those old vids..it was actually running on TWO cylinders lol.
didnt die because of too much boost or anything..died because it overheated/no coolant..
let that be a warning to everyone to make sure they check their coolant and watch their temps hehe
CMF_Yom
Wow nice work of that aaron!
How many KM were on the engine when it finally popped and what was its service history like?
EDIT: WOAH! Was that engine making any bottom end noise while you had it?
EDIT2: What on earth happened to that timing chain sproket?
CMF_evade
160k??
No bottom end noise..bearings look a bit..tired..
The timing chain sprocket..I was trying to stop the crank from moving when undoing the crank pulley..and yeah i just shoved a screwdriver through it..
Snapped right through hahah...lucky i dont need it. the crank pulley didnt end up coming off either.
anyone want to buy a head/block? suit rebuild :) cams too!
