CMF_evade
» CMF MemberWell today I stripped off more from the car.
Its officially N/A again!
Turbo/Manifold is off, oil/water lines still attached
Dump pipe is off
Intercooler/piping is off
Still left to go:
Unbolt the rear muffler and get the main exhaust/cat off
Swap dizzy over with standard one
Remove/Unwire ECU and return to stock
Swap sump w/ oil return from turbo with stock one
Remove braided water lines and reroute standard lines
Stock manifold back on
Oil feed grub plug back in
Will need to:
Get a stock exhaust made (depends if familyhack ends up buying the car..if he's just going to replace it then i wont bother!)
Dump pipe is off
Still left to go:
Will need to:
