The car is a k11 1.0 cg10de 5 spd manual with eccs. I live in Finland, the car is Scandnavian spec, so no a/c, no power steering, but heated seats, power plug for auxillary heating.
It was a gift from a family member, sort of like a gift that just keeps on giving.
It has done 252,000km and although I have a UK Haynes Manual it doesn't cover my car for this problem. The car starts ok. It then idles at 1500-2000rpm. When you drive it has a lack of power at light throttle, and then surges like you are about to run out of fuel. When it is up to operating temperature it has the same problems, the idle will still be high(1500rpm) and lack of power, blipping the throttle at the lights or driving hard will not alter this. I have changed the air filter, run a fuel additive, no change. The exhaust has black soot and it is using alot of fuel for a 1 litre car. It can run a little better with a full tank of fuel, but not always. Also it has black smoke on start up and runs rough, but only when it has been plugged in, eg it is minus 10 deg C, the heater warms the interior heater, then this heats the engine coolant. I know this is an Aussie forum, This may help explain this regional difference.
www.parkingheater.com/int-products/functionality.html
I haven't had the black smoke with other cars though..
My next step will be to change the fuel filter and then the spark plugs. Note the car is standard and I am using official Nissan parts.
Any suggestions?
Any suggestions?
