I was driving down some country roads today and got stuck in some mud. I managed to free my self with a little shunt from my passenger, but after that the engine started behaving oddly and I think the clutch started to slip.
Basically, if you take your foot off the throttle it fires really unevenly and will eventually stall. If you even touch the throttle, the engine will rev up to around 3k and it's practically impossible to control it at all. Had to drive around 10 miles with this and it proved really difficult. There wasn't a power loss on hills but when changing gear there'd be no power untill you took your foot fully off the throttle and reapplied.
Any ideas?
Problem solved. The one of the hoses came off. After much fiddling with the idle settings to try and fix it, it got fixed.
Any ideas?
