engine timing
CMF_frank2
i assume we,re talking about ignition timing, and i think the ignition map ends at about 4k rpm (baguete posted up the stock maps/tables on his MSC blog iirc)
but valve timing is well worth tweaking on a track car imo (mine are ghetto adjusted by filing the dowels down lol :) )
frank
CMF_sikK11
Thanks Kovert though i cant read japanese and cant seem to find a contact them to see shipping costs etc. Very keen on them though as i need to take up the difference in the timing that will be caused from the machine work i am having done.
CMF_Akinari
@frank
just wondering to how much deg adjustment did you do to the valve timing on your engine?
chains got a little slack since my last head shave so also had to file down the cam gears.
aki
CMF_frank2
Akinari WROTE:
"@frank
aki
if you file the dowel 1/2 way down aki, you have infinate adjustment eh (ie, you can turn the flat side round and use the next tooth of the sprocket)
i,ve set my 260deg/10mm lift cams so that all 4 valves are open 1mm @ tdc at the mo (which is easy to measure with a depth gauge from the shim top to the bearing cap top)
frank
CMF_EBBdude
here is another method that i have used for a long time on the Micras:
Works a treat and easy to have reference of what you do with the angle-finder :)
CMF_EBBdude
here is the picture of the camgears and how i modify them :
No , they never come loose as i use a diamond-powder between the gears and the camshafts to securely lock tem in place....
