Hi,
I recently became a proud owner of a 51 reg micra, with 48000 miles on the clock. I have noticed that on idle there is a quiet ticking noise coming from the rocker cover... I assume that is the timing chain? Any advice/ideas are appreciated
As you can see I've already swapped out the stock gear knob for something more individual... I was wondering if I need a sticker of the gear pattern for it to pass its MOT? Or should I just re-install the stock one for the MOT?
